I have a fairly specific question related to three-way switches. While I understand in principal how they work and how to wire them (I think anyway), my specific wiring is not generating the expected results. Here is the current wiring:
---------- Switch 1: Switch 2: ---------
| Power |---B---Common Common------W---X---B---| Light |
| source |---W Traveler----B---Traveler W---| |
---------- | Traveler----R---Traveler | ---------
----------------X------------------------
Legend:
B = Black wire
W = White wire
R = Red wire
X = Splice/wire nut
The expected result is that both switches can independently control the light. The observed result is that one switch overrides the other (the overriding switch must be on for the light to be on, and, if it is on, the other switch will cause the light to flicker when toggled, but will not actually turn it off).
Given the above, am I doing something wrong or could one or both of my switches be faulty? (They are brand new, but at this point I'm having difficulty finding another explanation.) Thanks!
