I'm trying to supply 3 outlets in a shower from ONE output of a digital mixer. I want to be able to control the flow to each of the outputs individually and balance them as I need.
I've spoken to a number of technical support lines and their initial response has generally been "You can't do that", but with no explanation as to why it's a problem.
When pushed, one person suggested that the control circuit in the mixer MIGHT shut down the mixer if the outlet is constricted too much. The feeling was that it would probably reset itself eventually but it might take a long time and, potentially could cause damage to the mixer if it happened repeatedly. This seems plausible to me.
Does anyone have experience of this or could you give any real reason why manufacturers are telling people this can't be done?
