Fitting a finished laminate door. Routered hinges and pre-drilled before screwing. Screws nearest the edge of the door caused a ripple as if screw was pushing it the laminate out. checked screws were straight. Any ideas?
You have a picture handy? – James Aug 27 '14 at 15:42
1The MDF or chipboard on laminates is not very compressible or forgiving. Sound like you needed a larger pilot hole. – bib Aug 27 '14 at 16:11
Add a comment
You need a bigger pilot hole for sure. If needed, point the holes inward a bit but not much.
