I went to tile upstairs bathroom floor and when we pulled up old linoleum and replace subfloor that was rotted we discovered 1 1/2" of concrete poured on top of old subfloor. Why would somebody do this?
It was (and still is) common to float cement on top of the floor for installation of ceramic tile. It provides a level and firm substrate to which tile mortar (thin-set) will adhere. 1 1/2" seems a bit thick though, maybe there were irregularities with the floor which had to be compensated for. I try not to float so thick unless I have to, and now I use cementitious tile backer board when appropriate. Or sometimes I mortar the tile directly to a smooth firm plywood subfloor in new construction applications.
    Perfectly normal thickness for this type of install - it's not thinset, it's not done the same way as thinset. Tile direct to plywood is not a recommended method.
    Aug 25, 2014 at 14:09
  • @Ecnerwal, all due respect, there are polymer fortified thin-set mortars specifically designed for direct application to sound plywood flooring that does not exceed maximum deflection specs. I have had very good results, proper application is key. Check it out: custombuildingproducts.com/TDS/TDS-118.pdf Aug 26, 2014 at 0:57
