How do I frame this corner? There are already two walls up (the one on the left that will become a closet), but that the corner where they meet is a steel post. Obviously I can't move that, and I can't move the walls as they support the stairs.
For what it's worth, the distance from the pole to the edge on the right side is 15/16" (and that's being generous) and about 1 1/4" to the bottom.
  • Is the post inside the line of both walls? How far?
    – DJohnM
    Aug 24, 2014 at 1:14
  • are you planning on applying some type of sheetrock as a skin to this wall? Aug 24, 2014 at 3:24
  • Was this question resolved? Was an acceptable solution accepted?
    – user113627
    May 24, 2021 at 12:24
if the post is within the line of the walls:
Blue is existing, red is nailing strips, green is bulkhead...
  • What is the yellow in the picture? FWIW, I only have 15/16" on the right and 1 1/4" on the bottom MAX. Aug 24, 2014 at 19:05
  • Yellow is a batten to help tie the two greens together. You can use 3/4" planks for the green bulkhead, with a 1x1 batten inside the corner for extra strength. Aug 24, 2014 at 19:47
Build a wall in front of the short wall with the studs oriented flat. Use a PT 2x2 for extending the sole plate. Block the end solid to the post with ripped studs as required to strengthen corner.
Blocking is lumber used for additional nailing surfaces and/or to create rigidity in the direction perpendicular to the primary framing members.
Solid blocking is blocking which fills a void.
Cost is an inch and a half of additional thickness.
  • Seems to make sense. I plan on putting a closet door in the short wall. Will this cause any problems? What about the drywalling the 1.5" on the (left side)? Is that advised, or should I just rip down the drywall that's there now and just extend with a full new piece? "Block the end solid to the post with ripped studs as required to strengthen corner." I assume by block the end solid you mean put the studs like an L in the corner. Can you clarify "as required to strengthen corner"? Aug 24, 2014 at 4:54
  • @2LeftThumbs See definitions in my edit answer. Finishing the thicker wall might require some additional trim at the new door depending on the aesthetic objective.
    – user23752
    Aug 24, 2014 at 14:20
  • So I was just looking at it and I'm wondering how I would add the blocking at the corner as the blocking would be directly under the steel beam? Aug 24, 2014 at 19:09
