I had a new vinyl floor put around 8 months ago. There is a square in the middle where it has damaged the floor. It is in the middle of the kitchen floor. Is there anything I can do to make this look better without having to replace the whole floor?
  • Are they vinyl tiles? – Nathan Aug 23 '14 at 9:29
  • "There is a square in the middle where it has damaged the floor" is unclear. What has damaged the floor? – TDHofstetter Aug 23 '14 at 12:45
  • A photo might help people advise what can / can't be done. – John Aug 23 '14 at 13:36
If, by "a square" you mean that you have rigid vinyl tile flooring (that typically comes in 12"x12" squares) you can pull up and replace a single tile (or have that done, depending on your preference.)
If you have sheet-type vinyl flooring where one piece covers the whole floor, you either need to accept some new seams or replace the whole thing.
Or put a rug over the damaged area ;-)
