There is a wooden frame in my kitchen and due to cooking/heating the wooden frame right above my burner is become greasy.
how i remove that greasy material from wooden frame, as i tried to remove it from water with no luck.
Most household degreasers work just fine. Krud Kutter works great, Lysol lemon degreaser also works well.paint thinner even works well as a degreaser
  • Is it all good on wood?
    – Usman
    Aug 21 '14 at 12:51
    Odds are if this is a couple years in the making (I know mine gets gross before I do anything) you are going to have to spray and let it penetrate for a little while, and it will likely take a few coats.
    – James
    Aug 21 '14 at 13:42
  • i spray this....and leave it for half a day, then wiped it . I do this step for two times and it remove grease...thanks
    – Usman
    Aug 22 '14 at 5:09
