I came across this light bulb socket in a piece of furniture built in 1969 in America. It's 2014 and I'm in Britain so frankly I have no idea. It's right down inside the thing so this is the best photo I can get.
interior light bulb fitting
I've worked with American pieces before but I don't recognise this kind of fitting. It doesn't seem to be threaded as an Edison Screw bulb usually is. Any ideas?
    Are you sure it's not threaded. Stick your hand down there to the ceramic part. It looks like a totally standard Edison base, if threaded.
    – Bryce
    Commented Aug 21, 2014 at 10:44
  • It does to me too but the inside surface of the socket is completely smooth. It's about the right size for an E27 but no threading and I was wondering if it might be something that has fallen into disuse. I was considering popping an E27/E26 in first and letting gravity hold it in but I don't want to risk it without an opinion. Commented Aug 21, 2014 at 10:56
    What is the internal diameter of the socket? In what orientation is the fixture intended for use? Could it be intended for specialized use?
    – user23752
    Commented Aug 21, 2014 at 12:29
I've owned a light socket exactly like that one - identical in size to an E27 but totally lacking in internal threads. Mine was simply a manufacturing screwup - the rest of the sockets on the shelf, with the same product number, had the expected internal threads. I got mine all the way home and installed before I noticed the flaw. The store was quite happy to exchange it for a "real" socket that worked.
Replacing that socket with a normal threaded E17 socket is an easy job.
