What type of paint shall I use when painting a non-removable, wooden shelf with a shiny, dark-brown veneer? I want to apply white colour. The problem is that the shelf is almost non-removable and it is in the bedroom, so I don't want to smell the oil paint in the night. Any suggestions please?
    Almost non-removable is, thus, removable - so take it out and paint it - dealing with the difficulty of removal/installation will probably be less of a pain than dealing with inferior paint options, in the long run. – Ecnerwal Aug 20 '14 at 15:58
  • I will consider that option, but the shelf is mounted onto a plasterwall, and I'm afraid that the process of disassembly would loosen the brolly anchors that I used, especially because they are open inside the thick wall, not outside. The shelf itself is thick and heavy and the books only add to the problem... – ellockie Aug 20 '14 at 22:39
Solvent based primers are the way to go on top of Poly or other clear coat. If you don't want to deal with the smell though you will need to sand it well and apply a surface prep fluid. I personally use a product called no sand (yes I still sand before I use it). This softens the top coat you are working with allowing a latex paint to stick better. It will still not be as durable as it would with a solvent based primer.
If this is a high traffic shelf (a bookshelf that is used often for example) I would suggest finding a time you can sleep in another room and use the better primer, that said if it just holds pictures or decorations then you can get away with the method mentioned above just fine.
Make sure you read the directions on the no sand well.
  • Thank you. Yes, it is a bookshelf, so I'll try to use a better primer according to your suggestion. – ellockie Aug 20 '14 at 22:28
  • Just to be clear, even with a good primer, surface prep is important. Sand and clean it well first. – James Aug 21 '14 at 16:36
  • I see. Good to know. Initially I was just going to paint without any preparation :) I'm glad I came here. Thanks! – ellockie Aug 21 '14 at 22:33
