I need to replace the lights in the below shown light ceiling cover. I have read another post on this forum and tried those methods I.e. sliding the glass cover between the metal holdings or trying the move one of the side brackets but it doesn't work. Any advice would be greatly appreciated. Main light cover
All three side holders are the same
Holder from a differt angle
  • Could you photograph the other two clips for us? Just one "profile shot" like your second photo above would suffice. Aug 24, 2014 at 15:29
Usually, ONE of those clips will be spring-loaded while the other two are fixed (as shown in the photos).
  • Hi, I tried moving all the clips it didn't budge. I was worried that the clip would break
    – Alex
    Aug 16, 2014 at 20:51
  • Hmmmm... could you photograph the other two clips for us? Just one "profile shot" like your second photo above would suffice. Aug 16, 2014 at 21:02
I had a light fitting like that. One, but only one as I recall, of the clips will pull away from the light diffuser. When you find which one it is, pull it away and the diffuser will simply slide out from the others.
