I want to build a 4'6" bed 6' up in the air which will be attached to the walls of my bedroom on two sides (so three corners of bed attached to wall) and have a wood 'leg' coming from the ceiling beam to the bed for the fourth corner. One wall is a chimney breast so 3'6" of the length of the bed will not have wall to attach to. The other wall is not load bearing so I would be attaching to its joists.
Has anyone ideas of how thick the wood would need to be? I hope to have the slats going straight to the edge of the bed to save room as my room is tiny. I thought of perhaps using 3" x 1" attached to walls and across to 'leg' and at least 3" x 3" for the 'leg'.
This bed is for adults not children.
I was thinking I might need to spread the hanging load by attaching wood across two or three ceiling beams and hanging the leg from that. Does that sound like a good plan or is the whole thing ridiculous?
