Rather a simple question, I want to route some cables under the house with a raised perimeter foundation.
The question is, how should I pass the cables I'm routing from under the house into the wall up above?
This is the closest resemblance to my foundation (from my untrained eye)
Drill up into the wall
Drill on an angle
You could try and dill up from underneath at just the right angle. Though this might be difficult, since you may not have much room to work and getting the proper angle could be impossible.
Drill at an angle
Use a flexible bit
In some situations, there might be enough room available to get a flexible bit into position from below. Though again, space may be limited making it difficult.
Drill from the bottom with flexible bit
Drill down
The more appropriate way to accomplish this task, is to drill from the top down. Start by cutting an access hole in the wall. About the size of an electrical box will do. This might be convenient, if you're installing a receptacle or something in the area. If you're not installing a device, cut the hole large enough to give yourself plenty of room to work. Patching a large hole in drywall is just as easy as patching a small one (sometimes easier).
Once you have the hole, use a flexible drill bit to drill down through the bottom plate. Use and alignment tool, to make sure the bit is in the proper position.
Drill from the top with flexible bit
Placement tool
Flexible drill bit placement tool
Flexible bit
Flexible drill bit
Man drilling down through wall
Man using a flexible drill bit
Careful measuring and (for exterior walls) a right angle drill, generally does the trick. Note that from below you generally can't see where the walls are, as you're looking at floorboards.
With something like this
http://www.screwfix.com/p/armeg-sds-plus-channelling-chisel-30mm/16724
If you are going to remove the skirting boards, a normal SDS chisel or drill bit is usually enough.
