Our house is less than 6 years old and our cabinets are peeling. How can I fix it?
    What are the cabinets made of: plywood, MDF, particle board, etc.? Are the doors made of a different material than the rest of the cabinet? If so, are they both having the same problem? What are they faced with: paint, polyurethane, melamine, etc.?
    – Niall C.
    Commented Aug 1, 2014 at 23:53
    I agree more info needed, but anything peeling is going to require sanding or stripping before refinishing. Commented Aug 2, 2014 at 15:31
  • I'm going to say particle board...? The peeling is happening to the " high traffic" cabinets, but it's not like they are being scratched. The " finish" is flaking off.
    – Amanda
    Commented Aug 2, 2014 at 16:28
You are going to have to re-finish. If it is just the doors, I have seen people leave the cabinet face-frames alone and just refinish the doors. If it really is particle board there will likely be no way to restore them to an acceptable "wood-look" finish; you will probably need to consider painting them.
To paint, make sure you sand all surfaces until any material that is peeling, AND any material that looks like it might peel, is removed. Fine sand to knock down any gloss, then wipe the surfaces clean with mineral spirits (paint thinner), turpentine, lacquer thinner, or some other solvent. Prime with a high-hiding latex binding primer like BIN 1-2-3, then use a good quality gloss or semi-gloss paint with a professional grade paint brush (don't skimp on the paintbrush for the finish coat, your end result will be way better).
it's a lot of work, but nothing good is ever easy.
  • it will be easier if you remove the doors and lay then on sawhorses outside for sanding and painting. And remember to ensure adequate ventilation when using solvents and extinguish sources of ignition. Commented Aug 2, 2014 at 21:11
