There is plenty of room to install the junction box on the other side of the wall and I would rather not put a box on the outside of the wall. Can I simply connect the wires in the junction box on the opposite side of the wall and mount the fixture to the brick wall?
  • It depends on the construction of the light. Please post an image. Commented Jul 31, 2014 at 18:17
So long as all the connections are inside the junction box you should be fine to do that.
    Unshielded wires running through a wall thickness into a fixture attached to a structural surface, not a box?
    – bib
    Commented Jul 31, 2014 at 1:21
