My basement is partially finished. One room which is not finished, that I'd like to finish, sits below the garage. The room is surrounded by 4 walls of concrete blocks, has a concrete slab floor, and has steel beams running the length of the ceiling.
I plan on framing out the walls with 2x4 studs and anchoring them directly into the concrete. No problems there. The problem I'm trying to understand is how to frame the ceiling.
There 6" steel joists that I assume are holding up the floor above. How can I frame a ceiling with these beams up there? I don't want to install a drop ceiling because this room will be used as a home movie theater and I want to have as much vertical space as possible.
