I drilled 2 large holes for mounting a flat screen in the bedroom. One hole is in a wood stud and the other is a metal stud. I will be renting out our apartment and will be taking the TV down and filling the holes and repainting walls. If I ever plan to move back into this apartment and mount a TV again in the same spot, how do I avoid not drilling in the same exact spot? Basically, I don't want to hit a portion of the same hole and create an even larger hole, making it very unsafe to mount a TV. Is there a way to mark the spot so that I know to avoid it in the future?
Is this even a concern? Shouldn't it be obvious when installing a wall anchor that it is secure? (The screws don't strip when torquing them, and you should always load-test to at least 2x the use load.) It's probably more likely that you catch the edge of a stud or find a void where a knot was than to find the same hole again. Also, you could fill the hole with a mixture of sawdust and wood glue which would be quite strong and re-drillable.– PaulAug 1, 2014 at 16:29
Chip away the drywall over the hole and install a Stud Plate. These are designed to stop anyone from drilling into a wire that runs through a stud.
Patch the drywall. Next time, if you can't find the location, and accidentally drill in the same spot, you'll hit the stud plate.
This stud plate idea is the best. Later to find where they are in the finished wall just run a strong magnet over the wall area.– Michael Karas ♦Jul 29, 2014 at 4:45
Why not just measure the height of your bracket and keep note of it, then next time mount it a few inches higher or lower so you don't risk hitting the same spots?
I suppose you could also plot the X,Y co-ordinates from a corner of the wall and mark those spots to avoid when you move back.
Why not just leave the bolts (lag, I assume) in the holes, screwed in below the level of the wall; then patch the wall. You can find them with a magnet if you ever want to reuse them.
