Blackhawk 47" chest from restorationhardware.com
I don't plan on making a chest of drawers but am interested in the techniques involved so I could apply them to other furniture.
EDIT: close up picture
    I think you need a Robbie the Robot. – bib Jul 25 '14 at 18:01
  • It's probably just an aluminum skin over standard secondary-wood construction. If so, all you need is a way to cut and bend the aluminum pieces. Saw with metal-cutting blade would probably distort the metal less than tinsnips would. File and/or abrasives to de-burr (and probably slightly round over) the cut edges. A bending brake would help, but you can also just force the metal around a suitable form (possibly the wooden frame itself) -- I've seen that done with brass, though scoring the bend first helps. Whatever nails you consider adequately decorative to hold the aluminum in place. – keshlam Jul 25 '14 at 20:49
It appears that those are thin pieces of tin nailed to a wooden cabinet with brass tacks. I think it is quite cool actually, sort of steampunk.
To do it large scale you would be best served with a sheet metal shear (think of a heavy duty paper shear), a pinch roller (adjustable twin steel rollers mounted vertically which you spin with a handle whilst passing sheet metal between, to set a curved bend), and maybe a sheet metal "brake" (a sheet metal bender for straight bends as opposed to curves). Also various metal working tools: vise grips, awl, tin snips (straight, right-hand, left-hand), various files, ball-pene hammers, small anvil, etc.
You can buy some "DIY" sheet metal work contraptions that combine a roller, shear, and brake for fairly cheap. Check on e-bay.
| improve this answer | |
  • Screwed, not tacked; and the metal can't be too thin as the edges in the close ups do not appear to be razor sharp. Perhaps 12 to 14 gauge. – Wayfaring Stranger Aug 25 '14 at 13:39
  • @Wayfaring Stranger, my answer was posted prior to OP edit with close-up pic. I could not see the screw heads in the original pic. Looking carefully, I think the edges may actually be rolled over/folded to prevent sharp edges. – Jimmy Fix-it Aug 26 '14 at 1:03
