Currently I have a closed stringer staircase against a wall in my home, and my plan is to convert it into an open stringer staircase. I have looked underneath the staircase and there is no central stringer, just three triangle bits against the join between the treads and risers.
How feasible is this conversion and would it be a case of simply cutting the tops of the stringer in line with the treads, or a case of adding a central stringer maybe?
Just to aid my question I have attached a pic from underneath and how it looks above
underneath
top
treads
bannister into ceiling
4 Answers 4
It depends on how the particular stair was constructed. Although the absence of a central stringer is evidence that the treads are capable of spanning without the support of a riser, it is not proof that they are adequate for the span. Likewise, the absence of a central stringer does not mean that the stair is laterally stable without risers.
Even assuming the stair is constructed to withstand the removal of the risers, the feasibility of 'simply cutting the tops of the stringer' has a lot to do with what constitutes feasibility. Risers stiffen. Bouncing treads or squeaky steps are not consistent with the intent. What performed well before, may not perform well after modification.
In addition, aesthetics probably plays a role and might even be the driving motivation. Just having open risers is unlikely to be enough, they need to look good, and the ease with which the desired results can be obtained is probably also a consideration. Sawing and cutting and patching a closed riser stair to the point of an aesthetically satisfactory open riser stair is likely to be extremely labor intensive. Particularly given that errors are part and parcel of the learn as you go method one must use when tackling a problem without a straight-forward solution.
So sure, it might be feasible. That doesn't necessarily make it cheaper or easier or more cost effective than simply replacing the existing stair with something close to what you actually envision. Cutting out the risers doesn't change the basic fact that it's a construction project where quality of fit and finish matter.
  • Apologise for not being clear and not using the correct terminology, I didn't want to remove the risers, I just want to cut the stringer so that I can a) have treads extended to the end and b) have a bannister which comes slightly in as at the moment the current bannister goes into the ceiling.
    – Shak
    Jul 24, 2014 at 15:29
The problem you have is that on a staircase designed with open stringers, the tread sits on top of the full thickness of the stringer, and often sticks out a bit over. In a closed stringer setup, the tread is wedged in a dado (a groove) cut into the inside face of the stringer. Generally the groove is about half the thickness of the stringer.
If you cut off the sections of stringer over each tread, you make the stringer less rigid, both vertically and laterally. You also weaken the lateral compression that helps hold the staircase together.
Unless you can get an engineer (or very experienced builder) to affirm that the stair will be strong and stable enough after surgery, I would strongly urge you not to do it.
As an alternative, you might be able to insert a properly constructed open stringer inside the two existing stringers, sister (attach laterally) the new and old stringers, then trim the old. This would depend on whether you have sufficient access to the inside areas, and whether you can get adequate support on the top and bottom edges of the new stringers.
  • The back just has a piece of board covering it, and as for the support on the top, there is an opening to allow me to get the top section of an open stringer inside, the bottom would sit on a tiled floor, I would assume there would be a way of fixing it to the floor. I do feel that if I did cut the stringer above the treads it would result in it being weaken and given the amount of traffic the staircase gets I would not want to chance this,
    – Shak
    Jul 24, 2014 at 18:58
  • Also I'm not too concerned about the treads only being half the length of the stringer as it goes into the dado of the stringer as I would be replacing the treads, to get lengths that hang over the stringer.
    – Shak
    Jul 24, 2014 at 19:01
  • @Shak: If you are going to replace the treads, install a new banister/handrail and install one or two additional open stringers - aren't you 90% of the way to removing the entire staircase and installing a complete new one? Jul 25, 2014 at 14:27
  • You may be right, but I thought I would have to remove the treads, but I've seen some tread covers which I may use instead. Other than that one extra stringer and cutting one old stringer is all I'm doing. The bannister isn't exactly a major removal? Just a plank of which I will replace with spindles
    – Shak
    Jul 25, 2014 at 16:52
You will need to completely redo the stairs to convert to an open stringer. If you were to cut the stringer flush to the top of the stairs you will not have enough structural support left to safely support the stairs. From the pictures you provided, there would be about 2-3 inches of material left from the cut. Do you really only want that much material to support 12 feet of stairs?
What if you temporarily supported the stairway from underneath (use 1x10s or 2x10s against the bottom of the stairs, supported by vertical 4x4s) then cut out and remove the outside stringer completely. You could then use the bottoms and backs of the existing treads and risers as a template to cut a new heavy-duty stringer. Then you could replace the treads one by one. Make sure your finished width from new banister to wall meets or exceeds local code clearance requirements.
Buy hardware at your local mom-and-pop shop when you can, and buy American made products whenever possible.
