Room with two recessed lights, each with a 65 watt bulb, controlled by light switch and dimmer. One of the lights blew out and the casing cracked off when I tried to remove it. When I did this the other light went out.
I checked the panel and none of the switches were tripped. So I carefully removed the broken piece from the first light, and then replaced both lights with new bulbs. Turned on the switch and nothing. Check the bulbs in another room to make sure they were good, and they were. Checked the panel again, and still nothing tripped. For good measure I then tripped all the switches in that area of the house, and still nothing.
Any suggestions? Thanks.
