At a big home store today, all the black drain pipe was 'cellular core ABS' in 'schedule 40'. What does the 'cellular' mean? The pipe was very inexpensive.
11
What you have is not solid. There's a foam or cellular interior to the pipe with two thin layers of sold ABS on the outside.
  • It costs less and weighs less than solid pipe. Thus it's popular at home stores that compete on price.
  • Not every jurisdiction allows use of cellular pipe. However it's common in the USA.
  • You need to be careful about backfilling such pipe with sharp rocks, which can pierce the thin shell.
  • When gluing, it's a good idea to coat the ends of the cut pipe, as the foam can and will slowly transport air and water (for the same reason, this pipe is never suitable for pressure applications).
  • You can't use it for pressure applications: this is meant only as drain pipe.
  • The pipe is fragile if dropped (take a section and stomp on it, chances are it will shatter into fragments, where a solid pipe would just hurt your foot).
  • It's more flexible than solid pipe, which is good in some cases, but causes sagging in others.
Here's a picture from a pipe vendor, where the foam core has been made white to show the detail. The pipe I've seen in stores all has a black core that mimics solid pipe at first glance:
Cellular Core ABS Pipe
Look around you'll see various opinions on the stuff. Some plumbers say they love it because it brings them repeat business. The vendors all claim various advantages to the pipe.
  • What do you use instead? How do you get it? – Bryce Oct 20 '18 at 20:56
Cellular core seems preturnaturally disposed to warping. Not much worse things can happen than a belly in a sewer line. As I am not a professional whose livelihood depends on call-backs and regularly revisiting a jobsite to re-snake the sewers, I will eschew the use of this inferior so called product. YMMV😸
