After using latex paint and cleaning the brush/roller with soapy water, how do I dispose of the paint/water mixture?
Modern Latex paint has very low toxicity. I don't hesitate to wash the brush in whichever sink is available (being careful to make sure that I then wash all the paint off the sink in turn).
  • I have a septic system / leech field, is this safe for it? Apr 27 '15 at 1:49
  • I believe so. But I'm neither a microbiologist nor a sanitary engineer.
    – keshlam
    Apr 27 '15 at 2:11
First I brush out most remaining paint, sometimes I use old newspaper or old cardboard. When the brush is no longer leaving paint on the scrap paper I squeeze the brush between some absorbent paper a few times to squeeze out any remaining paint.
Only then do I wash the brush under running water in a utility-room sink, in which case the very dilute mix goes down the drain.
Paintbrushes are so cheap nowadays that sometimes I don't bother washing them (particularly for brushes that have been used with oil-based paints). I just buy new ones :)
For paintbrushes I am planning to use the next day, with the same paint, I find that wrapping them in clingfilm can sometimes prevent the paint drying in the brush and keep them usable without the effort of cleaning them. In this case it helps to have more paint on the brush.
My only experience is to leave the bucket of waste water out, and eventually (1 week) it will separate like oil and water. You can then pour out the water normally, and throw away the separated paint at the bottom.
You want to clean your brush / rollers in running water as far as possible, say in a sink or tub. I would probably clean the brush very well and simply change rollers between paint colors. If you need to roll the same color another day, just seal your roller in a 1-gallon ziploc bag or similar (make sure it's airtight), and you can use this easily enough even a few days in the future. I've read that you should freeze the roller you're planning on reusing, but have no personal experience with that option.
Again, this is only with latex paints. I'll defer to someone else for advice with oil-based paints.
Disclaimer: Ziploc or any other plastic bag, as long as it's airtight, won't matter. No endorsement suggested or implied.
If I'm doing another coat of the same color I put the roller in a plastic bag, double bagged and it's good to go for the next coat.
