Here are some photos of my backyard with rough dimensions.
Needing help with how to end a deck from cemented posts in yard (at rear of house), to my back door. My trouble area is above the concrete. Should I place a ledger board on house slab under siding and extend deck into yard on posts? Or is there a way to not have to attach anything to the slab? Would also like it to run deck to the door to step out onto deck. From door threshold to cement slab is 6 inches. Not sure on best approach here. Thanks for any help.
