I have a rotted hole in one of my exterior house vertical corner trim boards. The rot is about 3 feet up from the bottom of board. Rather than replace the whole 16' board, i just want to cut out a piece and replace it.
How do i cut off a straight section without damaging the siding next to it or the other side's corner board? I can't obviously use a circular saw. I cannot figure out a way.
This is a great project for an oscilating multitool.
osc multitool
The front blade (and there are several to choose from) oscilates from side to side in small strokes, allowing a precise cut in both depth and width.
There are corded and cordless models availble in a wide price range. Almost all would suit for your type of project. I think you will also find many other uses for the tool, making it a pretty good DIY investment, even for a beginner.
 Images and links are for illustration only and not an endorsement of any product or source
I agree that the oscillating multitool is the best tool for this situation.
In particular, one of the long narrow blades works well for cutting into a tight spot. You can plunge cut directly into the required spot, without needing hardly any side clearance. It works great.
multitool blade
I bought my multitool from a well-known cheap tool import company for about US$30, and they are even less than that when they go on sale. It would have been worth it for just one job, but I have had no problems and it has continued to work just fine. Easy to find inexpensive models by shopping on-line.
  • Great. I had thought about using that tool but was concerned that my wife wouldn't like me buying another power tool. However, considering i would be saving money on hiring someone, i may just do that. I've seen this tool usd on This Old House a lot.
    – user22998
    Jun 10, 2014 at 15:22
  • You will likely save a lot compared to hiring someone. And if money is tight, they might be available at a tool rental place (I haven't looked).
    – Grunthos
    Jun 10, 2014 at 16:19
