While remodeling my basement, I had several walls where I just put up furring strips and foam insulation rather than framing in a "real" wall. I used 1x2 furring strips and attached them with a ramset and 1 1/2 inch nails.
Problem is, putting the nails through the furring strips would quite often cause them to crack. I tried pre-drilling (didn't really help) and also tried using 1x3 strips in some places (helped a little, but not much).
Is there some trick to nailing up furring strips to keep them from cracking on you?
