We have ceiling fans with "regulators" that allow us to control the speed of the fan, so does reducing speed of the fan translate into power savings rather than heat dissipation in the control element?
-1
In general, yes slower speeds use less power. The fan motors typically are synchronous AC motors and use different windings or capacitors on the motor to create different speeds. There isn't a "dimmer" circuit or resistor speed control when you use the pull chain switch.
If you try to use a dimmer switch instead to change the speed that isn't designed for fans the quality of the power (power factor) can drop which can lead to additional inefficiencies.
  • right , it had a large capacitor in the regulator , its certainly not a dimmer.
    – diy101
    May 17, 2014 at 18:48
