I recently bought a used, Amana gas range. It works, for the most part, quite well. The problem is that the oven door is not making a proper seal with the range body, which allows too much heat to escape from the top, where the door meets the body. Over time, I expect that the amount of heat released will damage the electronic control panel.
Do any of you experts have a suggested course of action to take? I figure I could:
- replace the hinges (they feel a little light)
- tighten the hinges (how?)
- replace the oven door gasket with a slightly thicker one
Comments and solutions appreciated.
