I've seen two distinct cases.
In the house I currently live in, the largest room in the basement has a floor that is uneven. Basically it dips lower towards the middle of the room. I presume this is caused by the foundation beneath settling.
When I went to view a room for rent, one of them was on the top most portion of a large old house. The room itself was small but after a minute I noticed it was slanted, yet the floor itself was even. It was quite an unpleasant sensation, visually the room looked to be normal but you get the sense of imbalance. The current tenant told me he had sheets wedged beneath one corner of the bed to compensate. What would've caused the floor to be like this? Tangent: in the same room there was a small fireplace. Isn't it odd to have a fireplace on the top level of a house and in a bed room?
Is there anyways a slanted floor can be fixed? In the second case the floor was made of wood.
  • The whole house would probably have to be jacked up. Big bucks. May 1, 2014 at 20:18
Although it is impossible to say for sure without seeing the floors in question, I suspect it is a simple case of poor construction practice. The basement floor is most likely over a concrete slab. The floor may not have been leveled with framing. You did not mention what type of flooring was there, but I suspect the tile or carpet was applied to an uneven base. The upper story floor was most likely built long ago on the existing joists, with the same un-level results. In either case, the only way to level these floors would be to frame a new subfloor level, then install new flooring over a properly installed subfloor. There is no trick or shortcut to fixing situations like this. This can be an involved and expensive project, not a good DIY for amateurs.
As far as the fireplace is concerned, if the room in question was originally designed as a livable space, it is not uncommon to see a small fireplace. Before the days of central heating systems, many older homes (100 yrs ago) had multiple fireplaces. The concern by today's standards is if the assignment of flues is correct. By that I mean, how many and what type of combustible devices share a flue. There are strict rules on what fuels can share flues and an what elevation in a house. This is important as fumes or CO can invade through a flue from one device to another. Again, this would have to be inspected for safety.
  • You can also level a floor by jacking the house level again. In either case the OP seems to be renting so this is mostly pointless. And of course jacking houses can result in all sorts of interesting side effects as you return (or impose for the first time) level on things that have become used to not being level (or were never built level to begin with.) Ideally a process to carry out very gradually over several months...
    Apr 30, 2014 at 10:58
  • For the basement floor would it not be possible to tear out the carpet, pour concrete in, and let it settle in the low points?
    – Celeritas
    Apr 30, 2014 at 19:10
  • @ Celeritas: much easier said than done. the self leveling products are not as easy as they sound. Depending on how deep the dip is, it may be possible to level it with surfacing mortar, but since we have little detailed info, hard to say how extensive the repair would be. Sorry, you aren't gonna get an easy out on this one. Apr 30, 2014 at 19:25
