I have installed a pressure tank and the PSI is still about 90 PSI . Is this normal?
    what is the water source? City or well? – shirlock homes Feb 17 '14 at 12:10
The maximum PSI for a home water line is 80PSI. Low water pressure is below 40 PSI. You typically want 50-60PSI for your home. If the water pressure is rising while the water heater is running, you need to install an expansion tank (as Wallace mentions, +1). If the water pressure is always high, then you need to install a pressure reducing valve in addition to the expansion tank. It's possible for both of these to fail over time, so if you see symptoms indicating that you don't have one of these, then consider replacing it.
|improve this answer|||||
I had a similar problem after installing a expansion tank on hot water heater. It ended up being a faulty regulator valve at main line feed from city water. Once that was replaced the pressure went down to 50-60 psi.
