Contractor removed and threw away a 12' segment and now I don't have the right material!
  • What exactly are you trying to figure out? Where to get that same molding? – Steven Feb 16 '14 at 3:31
  • Where exactly used? casement, baseboard, window, wainscot header (aka chair rail)? – Fiasco Labs Feb 16 '14 at 4:55
  • Yes, what I'm looking for is what the profile is called, who makes it, and where I can get it. – ThePopMachine Feb 16 '14 at 6:16
What you have is a 4 1/2 inch colonial base trim. I can't tell you exactly the name or number, but if you take a small sample to your supplier, or preferably the same supplier your contractor used, they will have a chart that shows all the millwork profiles. What you have does not look unusual, so with a little footwork you should be able to find it easily.
| improve this answer | |
The profile shows it's a casing for doors and windows. Common colonial profile. Might need a table saw for the center ledge of the profile.
