I am doing a basement bathroom reno and wish to install an exhaust fan in the ceiling.
Since I have had the furnace replaced and now its direct vent out the side of the house , I have an existing furnace flue in the area that is no longer in use(5 inch). Is it possible to vent the exhaust fan through this ?
As there are windows, furnace vents, gas lines at the side it is almost impossible to add a vent on the side of the house. The rise for the old furnace flue is about 16 feet and I will need to add a couple of elbows to get to the flue.
I see no problem with using the old furnace flue for the bathroom vent as long as that vent has no other connections such as off to a gas water heater.
The 16' rise of the old furnace flue can represent a challenge for a small bathroom fan to push air through. The column of air presents a back pressure that the fan must overcome in order to be able to produce positive upward flow out of the flue pipe. A small capacity fan may be able to cause air flow to occur but it may be way less that what is needed to adequately vent your bathroom.
So I would suggest selecting a bathroom fan that has a greater than normal flow capacity than would be needed for your installation under normal circumstances.
  • A long vertical vent for the bathroom might have a lot of water condensed on the sides which would drain down and collect in some places where it could be a problem. Commented Apr 14, 2023 at 16:55
