Hi everyone, I paid someone to hang this cabinet in my bedroom. Is made of metal and glass, so it’s quite heavy and my skills are very limited.
The welded attachments at the back in which it was going to be hang were useless (super tiny), so the builder snapped them and then drilled a hole in the metal back of the cabinet, to screw through it.
He used two blue gripit fixings for plasterboard, however he had to substitute the original thick silver screws for another pair of copper, longer and thinner as there was a big gap between the wall and the cabinet and the originals were too short.
When I ask if it will hold he he said ‘it should, but don’t put too much weight just in case. Just some Knick Knacks’ The idea was putting some of my books and a small collection of rocks.
I have a baby on the way and the cot is going to be nearly under it.
If someone could tell me if it is safe or whether I should try to contact another professional to have a second opinion I would be very grateful.
I live in the U.K. (no earthquakes), the cabinet is at least 30 kilos and the wall is plasterboard. The thickness of the metal at the back is probably 1-2 mm. The screws are around 4mm thick. The cabinet is 80cmx120cm. I hired the chap off of AirTasker to put up the cabinet.
... the installer is unaware of, or does not care about, the consequences of his actions
