I have normal lights that want to replace by a dimmer. The wiring has two brown and one black cables (see foto). The previous switch had two L and two N sockets (see foto of the diagram on the back). The two brown cables were connected to the L (top cable to top L, bottom cable to bottom L) while the black to the top N socket. How should I connect the dimmer? See also foto.
If it is of any relevance, this is in the Netherlands.
Update: I connected black to ~, top brown cable to L1 and bottom brown cable to L2. The light works perfectly, but the outlets in the room do not. So I am guessing there was some sort of bridge?
