I am building a new house and would like to build a patio that extends the length of the house from one end to the other. My warranty would be voided if I pour the slab and it touches the home foundation. I am thinking about pouring the slab 6" from the home foundation and filling it with small stones. Would that work? Any other ideas?
1You are building, so the builder should be around to ask this question. By patio I am imagining a cement slab, so it touching or not should not hurt a concrete foundation.– crip659Commented Sep 10 at 18:26
This really sounds like a question for whoever is providing the "warranty."– HuesmannCommented Sep 11 at 12:49
1 Answer
This is almost more a legal question as to what exactly constitutes or defines "touching the house"
You could use PE foam expansion joints between the foundation and poured slab, and not have added any modification to the home. This again is a matter of interpretation.
I believe the flavor of the rule is that the builder does not want to be held responsible if the structure itself is modified. For example if you pour a patio and then add a roof tied into the original roof and then experience a leak.
