Not possible to use a conventional wrench.
file:///var/folders/7p/ccwl5rr50vl9k5m55fl7hx380000gn/T/TemporaryItems/NSIRD_screencaptureui_GlZgwA/Screenshot%202024-09-04%20at%206.24.03%E2%80%AFPM.png
An 8-point socket can be used to turn a square head bolt or nut. As a socket, it may be able to access fasteners that a conventional wrench cannot.
file:\\
means the resource is on your PC.https\\
means there's a resource that can be accessed through a web server.
