I want to relocate the location of my kitchen cabinet knobs, what is the best way I could fill in the old screw holes? Would I just use wood putty and then use white touch-up paint?
Thank you.
    It should work. The problem will be if it stands out or blends in enough to hide. Screw holes are usually tiny so that helps. Should try filling a screw hole in a hidden section(sides/inside) before trying.
    Commented Sep 1 at 21:19
    What are the cabinets made of, painted wood, formica, thermal foil, melamine?
    – RMDman
    Commented Sep 1 at 21:21
  • @RMDman It says the following “Door Material: 3/4" Dowel Jointed Hardwoods with Plywood Panels”.
    – olimits7
    Commented Sep 2 at 2:19
    It really depends on the finish (finish can be hard to match) and what the door looks like after the knobs are removed (they may have left an impression in the wood). It also depends on your tolerance for fixes that may not be perfect—are your eyes gonna be drawn to the fix every time you look at a cabinet?
    – Huesmann
    Commented Sep 2 at 12:23
  • Yeah, good points; I'm going to test this on one of the holes and see what it looks like. These are the kitchen cabinets I purchased. americanmadecabinets.com/collections/white-rta-shaker-cabinets/… I emailed them and they told me the touch-up paint to use for these are the following. homedepot.com/p/…
    – olimits7
    Commented Sep 2 at 14:10
If the cabinets are solid wood, with no covering (e.g. Formica, laminate, etc.), and including painted plywood, you can use wood filler, sand, and then paint.
If the cabinets are made out of any other material, including wood covered by Formica, compressed particleboard, etc. then use screw plugs. They are sold by the bag and in different sizes and materials. I like the ones made out of rubber.
I've used sawdust mixed with elmers glue before just making a thick paste.
