This question already has an answer here:
Just moved into a new apartment so I had to change my dryer plug.
However, after countless tutorials and videos I am a little confused with the current set-up. Is it right that the green(ground) and the white (neutral) are directly on top of one another? I see the ground screw to the left but nothing is on there...
So my question is when I install my 3 prong how will I ground it? Do I need to buy a ground wire and somehow attach it to the ground screw?
Tried to attach a picture but wouldn't let me because I did not have 10 rep.
marked as duplicate by Aaron, Niall C., HerrBag, Tester101 Aug 13 '13 at 14:43
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • See my answer to this question. Also note that in a 3 wire configuration, there is no ground wire in the cord. The cord is instead made up of 2 ungrounded (hot) conductors, and one grounded (neutral) conductor. – Tester101 Aug 12 '13 at 16:55
