My aunt has an ancient kind of washing machine that has no automatic control of incoming water. That is, to operate it, you manually open a valve in the wall, similar to this one:
This valve is connected to a hose that feeds directly to the washer. You wait for the drum to fill up (it takes a few minutes), and then you manually close the valve. You can let it start tumbling while it is filling up.
This has worked for years, but now she's having memory issues; so she opens the valve, leaves the room to do something else, and when she realizes, the washing machine is overflowing and there is water everywhere.
Assuming that it is not possible to simply buy a "modern" washing machine (third world problems), is there some time-controlled mechanism or equivalent solution for handling this kind of situation? I'm assuming a non-industrial setting.
I though about time-controlled auto-off touch faucets (the ones you press and water keeps flowing for a determined amount of time), but I couldn't find any that run for longer than one minute. I also had to discard some alternative solutions such as using a smartphone timer, not leaving the room, etc., which are not 100% foolproof, and are often incompatible with "old habits". Also, I'm curious about the existence of technical solutions to time-controlling water flow in a home setting, in general.
