The material on the ceiling is falling off. What are my patch options?
See photos: https://imgur.com/a/tw36DCE
I know the most effective solution might be to scrape any loose parts (which might be the entire ceiling, once I start scraping), but people currently live in this bedroom, so that doesn't seem like a good option right now. And I'm assuming that this is lead paint.
Also, I am getting an inspection done soon where I want the needed repairs to be relatively visible, so a full scrape and paint wouldn't be good for that.
Is there a way to temporarily patch the areas, to prevent the material from continuing to peel away due to gravity?
I don't think duct tape along the edges would work. (Duct tape along the edges, then cover the exposed areas with plastic and tape that up)
Thanks
*Edit- I originally said it was paint, but it appears to be stucco (popcorn ceiling). The material is very thick and stiff, unlike what I've seen peeling paint do.
Edit- I already addressed the water/moisture issue. This is the top floor of the house. The roof has these foot-wide air vent pipes, and the caps came off, so rain kept falling directly above this ceiling.
