Two days ago and previously the sink worked properly. Yesterday I noticed it was continuing to drain after a flush [through the drain pipe in purple]. The reason is that the actuator [in red] does not get lifted/float properly. A "fix" [but needed after every flush] is to simply lift the actuator [pictured in purple ] a little and let go.
This problem does not seem to be addressable via that screw on the actuator. Instead maybe some part of the broader mechanism is a little 'tight', causing the actuator/float to stick? What can be done to fix this: is there any cleaning or adjustment? If not what should I replace?
Update. I have found a more specific "fix" to this. The cylindrical black portion of the float gets "stuck". If I bump it to unstick it the actuator arm lifts up as well and then the draining stops. I did add a small shim to ensure the black piece were not contacting the back of the sink bowl (it was..). but surprisingly that did not make a difference
  • The float may get stuck if you have hard water deposits. It's worth wiping it down with a little vinegar to see if it helps. Commented Aug 10 at 23:08
screw in the thing that stops water flow so it turns off before it reaches the overflow.
  • I will take a look at that but suspect that is not the issue. Please see my update to the question. Actually that worked, but with more effort than expected . I will provide a side note to explain. Commented Aug 9 at 18:08
This "answer" is actually a further explanation of the one from @TigerGuy that I just accepted. Yes the answer was to turn the screw. I had not done it earlier because the screw was jumping around on the top where the head is and at the bottom where it meets the thread. [Note: the thread is not visible since I was unable to get a good exposure photo. It is inside the red rectangle].
So I was initially unable to understand whether the screw were simply broken. The answer from @TigerGuy made me more insistent to get the screw to work.
