I have a dishwasher and disposal on one breaker. The dishwasher stopped working and started flashing a maintenance light a few weeks ago. I have been doing dishes by hand.
Separately, I was using the disposal and it blew a fuse. I turned a screw on the bottom of the disposal to release any clogs and flipped the breaker. The disposal worked fine after I flipped the breaker to on again, and so because I was done with the disposal I turned off the light switch that turns off the disposal. However, then the disposal started running again with the switch in the off position. To turn off the disposal, I had to flip the breaker to the off position. When I flipped the breaker to on again, the disposal turned on even if the light switch is in the off position. So it is as if the light switch has somehow been reversed where off (on the light switch) means on.
My questions are:
- What might be causing this?
- Is there a deeper electrical issue that may explain the disposal and dishwasher problem?
- Is there an immediate safety issue?
I plan to have an electrician come out soon.
