I am transforming the side of my house from an overgrown mess into something practical, and once I cleared out all the mess I could see that there was a channel dug along it and thick black plastic underneath the rocks:
Notice the channel running from top to bottom as you look at the picture.
I think I understand the intent, but practically speaking I don't think this setup was working. The black plastic traps water indefinitely, which encouraged plants to send their roots through it and proliferate around the edges of this setup (already cleared in this photo, but they were finding any little nook and cranny to take hold, supported as it turns out by the abundant supply of water being trapped in the plastic).
Secondly, the channel is ineffective at routing water into the drainage system because the drain cover sits way higher than the bottom of the channel, and in fact sits higher than all but the rocks. So water would just pool in the channel and be held there by the plastic.
My plan, then, is to:
- Clear the entire area
- Remove the plastic
- Break up the soil
- Level out the soil
- Put weedmat down
- Put the rocks back in
Does this sound reasonable? I'm really second-guessing myself because I don't know if I'm overlooking some valid reason for the channel and plastic. As long as the tops of the drains sit below the level of the footpath (which they do), why would a channel be required? The plastic would prevent water seeping into the soil, but is that a bad thing?
UPDATE: Just adding some additional information here based on responses:
- I live in a subtropical climate. There's a lot of rain, particularly over summer, and it's never very cold (certainly not freezing)
- The footpath on the right in my photo is 3 feet wide, then there's my house
- The drain inlet connects to a conduit that runs down the side of the house towards the back, where it must connect up to a large, municipal pipe that runs through the back of my property (I have a grate in a corner of my property that allows me to see into that pipe)
