I had a window leak and had to replace a full 8'x4' of drywall. I cut the old area out, screwed it into the studs via drywall screws. Then I used drywall grid tape on the seams and premade joint compound to seal the seams. The bottom part will be behind the baseboard. The corner piece I first filled with spray foam, cut everything that expanded outside away and sealed again with joint compound:
Since it will be hard to match paint I am planning to redo the whole wall side but I really want to avoid repainting the entire room (since I have multiple smaller patches in other rooms as well).
One issue is that the wall had a fairly thick layer of old paints (~1mm) so it is slightly thinner. It also has a pattern:
What are the steps (and the right order) to arrive at a finish wall that matches the existing pattern and color as much as possible?
I am not sure if I need to do something on the drywall (add some plaster layer or so), how I can recreate the existing pattern as much as possible, whether I need primer and which, how I can find the color matching as closely as possible, whether I need to do anything behind the baseboard and in which order all of it should happen (e.g. caulking the baseboard to the drywall).
