These pictures are above my two car garage. I would like to build an attic space here. I am guessing the middle vertical supports are critical, and can’t remove those. But can work with that. The question is: Can I remove the diagonal supports and put down plywood?
Thank you!
Picture one - left side - circled supports I want to remove
Picture two - right side - circled supports I want to remove
