The key for this lock is very rusty and old and barely works, so I want to replace the dual cylinder deadbolt lock, below the doorknob, with a new lock.
https://i.ibb.co/hD381cr/20240718-095427.jpg
I don't see any screws on the deadbolt lock, and I tried to pry off the plate on the front of the lock, but it doesn't seem to work. How can I remove it so I can put a new one in?
Edit: new image: https://i.ibb.co/q9WXSYF/20240724-124835.jpg
    Check the bottom for a hidden set screw/pin. Might have to remove the bottom railing.
    Commented Jul 18 at 17:11
The knob removes by loosening the visible screws.
The lock cylinders are threaded into the lock body and secured by setscrews accessable from the edge of the door, located level with the center of the cylinder. Loosen those a few turns, then rotate the cylinders counterclockwise to unscrew them. Depending on what kind of protective ring the cylinders have around them and how stiff the connection is, it may help to insert a key blank and use that as a thumb turn to rotate the cylinder -- don't force it, and don't use any key that has deep cuts or that you would mind damaging, as warping and breakage are possible.
It is then possible to remove the lock body from the door, if desired. I'd do a basic inspect/clean/repair while I had the opportunity, but I know what I'd be looking for.
To reassemble, reverse these steps. The setscrews engage with the grooves in the cylinders to keep them from being unscrewed by anyone else.
  • Thanks! I finally got around to working on this again today. But I'm having a miserable time trying to find the set screw. Also the lock cylinder just does not seem to want to turn, possibly because the set screw is still too tight. Where might I be able to find that set screw? It's hard for me to see deep into the side of the lock cavities, but I don't think I see any screws. Edit: I added a new image to the post so you can see better from the side where the set screw might be.
    – ItsGiusto
    Commented Jul 24 at 17:48
  • I've tried sticking screwdrivers into the holes on the left and right side, centered vertically with the cylinder, but nothing seems to be turning. Maybe I have the wrong size screwdriver, could be too large.
    – ItsGiusto
    Commented Jul 24 at 17:55
  • Look into the holes with a flashlight. See what you are trying to turn. Find a thin screwdriver that fits it, get lined up on it, turn it. Going in blindly is far less likely to work.
    – keshlam
    Commented Jul 24 at 20:22
