I'm replacing siding and insulation on my house built in 1948. Existing sheathing is rough cut 1"x12" pine boards horizontally over the studs. When removing the siding I found a spot that is rotten and needs to be replaced. Should I find 5/4 x 12 boards to replace the bad ones or use 2 layers of 1/2" plywood so I match the same thickness, or is there a better option?
I'm dealing with the cause of the water damage, and may need to replace a stud or two. The damaged section is part of two walls, and I'm not planning on removing/replacing all of the sheathing on these walls.
My new wall build has rockwool in the cavities, 1" foil faced foam, fibercement siding.
Damaged area is about 2' x 3' on one wall and 1' x 4' on the other.
