I have a ceiling made of 12 mm thick drywall panels. The drywall itself is attached to metal profiles, but these profiles have holes every few centimeters. Now, I want to drill a small hole (6 mm) through the drywall (and potentially through the metal profile behind it, which is a few millimeters thick). It's not a problem if I hit the metal directly, as I can use a metal drill bit. If I don't hit any metal, it's even less of an issue. The problem arises when I hit the edge of one of the holes in the metal profile. The drill bit immediately slips because the drywall is very soft, and the hole becomes messy. What is a solution for this?
Here is a picture during the construction of the house some years ago. On the right you see the drywall panels of the ceiling and on the left you see the metal profiles below.
