I have a 1.5HP Delta 50-760 dust collector wired for 120V, rated 15A 120V / 7.5A 240V (3450 RPM capacitor start motor). It starts slowly and takes a while to spin up, so presumably it has a high starting current. It has fried two GFCIs and a dust collector remote control box, after maybe twenty hours of use. What kind of outlet can I use for this in a garage? Are there heavy duty GFCIs that will stand up to the starting current?
Flooding is not a concern.
Can I get around GFCI requirements by reconfiguring the motor for 240V (this is a built-in motor option)?
Am I better off getting a dust collector that draws less power?
VFD with 234V input for a soft start?
In the US, Washington State.
I would appreciate ideas.
Thanks in advance!
Edit: found the motor start capacitor had a puckered burn mark, and appears to have sprayed out its contents. Think I missed it because:
(A) I was too close to the problem,
(B) it spent a long time in storage; it must have failed so long ago that I perceived it as 'always' like this.
