Companion question to How to connect ENT to boxes and why is the nut missing?
I am installing PVC boxes and ENT with the fittings from the linked question (fitting + metal locknut).
Do I need additional cement for this or is it ok to just use the fittings?
I have seen somewhere there is Carlon cement but I can’t find it anywhere (in typical big box stores). If it is necessary, is it ok to just use normal PVC cement?
