Wine enthusiast model wbs-133CD.
Im- excuse me I'M- not sure what about "installed a bullet valve on the low side" is confusing.
A bullet valve is a self piercing valve used to access a closed refrigeration system. You install on the low pressure/refridergant return side in order to attach pressure guages and/or refrigerant dispensing hoses.
Problem is, the compressor didnt restart even though it was cool. You cant properly get a operating pressure reading or recharge the system if the compressor isnt operating.
I know the thermostat is working properly and that the compressor came on at some point durring the night, after my initial post, since it was hot this morning and the temp inside had dropped, but it cut out again (due to overheating) by the time I woke up.
Im trying to figure out why restoring power, even after the compressor cools, doesnt restart the compressor- it does start at some later time- but I cant, excuse me can't- I know that apostrophe is very important to get my point across- I can not determine why the delay or how long it is...
It almost certainly needs refrigerant, but the compressor has to be running and I can not spend the whole day watching and waiting. What can I do? or can anyone help me understand why it doesnt restart right away, how long te delay might be, what is causing it... so I can catch it running to properly test the pressue and refill.
Thank you for your useful correction on the use of apostrophes. Your welcome for my explanation of bullet valves.
