I'm rebuilding my deck. The support structure is made of 2x10 joists between steel beams. The joists are aligned 3/8" above the steel beam so that when the wood settles/dries, the beam doesn't make a bump on the composite decking.
Since my deck boards are the same width as the steel beam, I wouldn't have any space to attach it over the beam.
I'm thinking of putting 2x4, flat, on top of the joists. See ASCII art below. That would allow having a nice flat surface bridging over the steel beam. They would be held down with deck screws. Furthermore, the deck tape on top of the 2x4 would keep the water away from the joist.
|2x4 |
|2x |
| 10|
How bad of an idea is this? Why?
(The second half of the joists, in front of the middle beam, is missing for now, but there will be joist on that side, too, towards the photograph.)
